[Variables] Cannot create a variable to get Lambda function filter by their tag
I am currently struggling to create a variable to get only the lambda function with a specific tag.
I tried many things such as dimension_values(eu-west-1,AWS/Lambda,Duration,FunctionName[Tag.Tagname:TagValue])
So far, I was not able to retrieve those values… Can you please help me to get those value?
Thank you!
Vincent
Hey how is everything
I was with this same need, I created this dashboar by api and it worked well
