Grafana v10.4.15 on Ubuntu Server 22.04
- What are you trying to achieve?
I want to make variable that would:
- Show metrics in panel depending on which labels are selected (e.g. show host1 and host3 when they are selected in the variable)
- Only if “All” is selected, sum all the labels together so it would display one aggregated timeline instead of all of the timelines one on top of another.
- How are you trying to achieve it?
I successfully set variable for label value, selected metric, selected label value and checked the “Include All option”, but the All option shows all timelines on top of each other. I want to have it aggregated (sum) into one timeline
I also tried to do the sum beforehand in the query. It worked kind of well but when i selected multiple labels to show, it simply shows aggregated timeline.
- What happened?
Including the sum into query worked better but when i selected multiple labels, it showed one aggregated timeline instead of showing 2 timelines one on top of each other
When i select one label, it should show one timeline. When i select multiple, it should show multiple lines in the same panel. When i select “All”, i want it to aggregate all timelines into one.
- Can you copy/paste the configuration(s) that you are having problems with?
Sure:
"annotations": {
"list": [
"builtIn": 1,
"datasource": {
"type": "grafana",
"uid": "-- Grafana --"
"enable": true,
"hide": true,
"iconColor": "rgba(0, 211, 255, 1)",
"name": "Annotations & Alerts",
"type": "dashboard"
"description": "REDACTED",
"editable": true,
"fiscalYearStartMonth": 0,
"graphTooltip": 0,
"id": 120,
"links": [],
"panels": [
"datasource": {
"type": "prometheus",
"uid": "raInckNGz"
"description": "",
"fieldConfig": {
"defaults": {
"color": {
"mode": "palette-classic"
"custom": {
"axisBorderShow": false,
"axisCenteredZero": false,
"axisColorMode": "text",
"axisLabel": "",
"axisPlacement": "auto",
"barAlignment": 0,
"drawStyle": "line",
"fillOpacity": 100,
"gradientMode": "opacity",
"hideFrom": {
"legend": false,
"tooltip": false,
"viz": false
"insertNulls": false,
"lineInterpolation": "smooth",
"lineWidth": 1,
"pointSize": 5,
"scaleDistribution": {
"type": "linear"
"showPoints": "auto",
"spanNulls": false,
"stacking": {
"group": "A",
"mode": "none"
"thresholdsStyle": {
"mode": "off"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"unit": "Bps"
"overrides": []
"gridPos": {
"h": 11,
"w": 24,
"x": 0,
"y": 0
"id": 1,
"interval": "30s",
"options": {
"legend": {
"calcs": [],
"displayMode": "list",
"placement": "bottom",
"showLegend": true
"tooltip": {
"mode": "single",
"sort": "none"
"targets": [
"datasource": {
"uid": "raInckNGz"
"disableTextWrap": false,
"editorMode": "builder",
"expr": "rate(gost_service_transfer_output_bytes_total{host=~\"$Grouping\"}[$__rate_interval])",
"fullMetaSearch": false,
"hide": true,
"includeNullMetadata": true,
"instant": false,
"interval": "",
"legendFormat": "{{host}}",
"range": true,
"refId": "A",
"useBackend": false
"datasource": {
"uid": "raInckNGz"
"expr": "sum(rate(gost_service_transfer_output_bytes_total{host=~\"$Grouping\"}[$__rate_interval]))",
"hide": false,
"instant": false,
"legendFormat": "Aggregated",
"range": true,
"refId": "B",
"useBackend": false
"title": "Download rate",
"type": "timeseries"
"datasource": {
"uid": "raInckNGz"
"fieldConfig": {
"defaults": {
"color": {
"mode": "thresholds"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"unit": "decbytes"
"overrides": []
"gridPos": {
"h": 8,
"w": 6,
"x": 0,
"y": 11
"id": 2,
"options": {
"colorMode": "value",
"graphMode": "area",
"justifyMode": "auto",
"orientation": "auto",
"reduceOptions": {
"calcs": [
"lastNotNull"
"fields": "",
"values": false
"showPercentChange": false,
"textMode": "auto",
"wideLayout": true
"pluginVersion": "10.4.15",
"targets": [
"datasource": {
"uid": "raInckNGz"
"expr": "sum(increase(gost_service_transfer_output_bytes_total[24h]))",
"instant": false,
"legendFormat": "__auto",
"range": true,
"refId": "A",
"useBackend": false
"title": "Downloaded over last 24 hours",
"type": "stat"
"refresh": "1m",
"schemaVersion": 39,
"tags": [],
"templating": {
"list": [
"allValue": "",
"current": {
"selected": true,
"text": [
"All"
"value": [
"$__all"
"datasource": {
"uid": "raInckNGz"
"definition": "label_values(gost_service_transfer_output_bytes_total,host)",
"hide": 0,
"includeAll": true,
"label": "",
"multi": true,
"name": "Grouping",
"options": [],
"query": {
"qryType": 1,
"query": "label_values(gost_service_transfer_output_bytes_total,host)",
"refId": "PrometheusVariableQueryEditor-VariableQuery"
"refresh": 1,
"regex": "",
"skipUrlSync": false,
"sort": 0,
"type": "query"
"time": {
"from": "now-3h",
"to": "now"
"timepicker": {},
"timezone": "browser",
"title": "Surfshark",
"uid": "bediv97gv91q8c",
"version": 14,
"weekStart": ""
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Not really.
- Did you follow any online instructions? If so, what is the URL?
No.
