Value to Time format
This is not only hilarious, but inspiring. Need to create a webhook that plays the song upon the countdown timer reaching 1 minute.
:joy: :joy: :joy: check that song out at 4.20. epic!
Thanks for all helps. I saw that you entered the cycle manually. I do add the number of litres by changing the number in the T2F enquiry, in my example 1000. It is great to find way to make a box in the dashboard to enter that value. I use costume variable but as you know It fixed on the top of the ashboard.
