Synology Docker, Grafana version 8.2.3 -
Value mappings like…
What happened?
I created 2 times (both second axis) the value mapping equaly, which means for the region between 0.1 … 0.9 I would like to see nothing. It is working for the left second axes but does not work for the right second axis. I heavily asume a bug in grafana. -
See screenshots above -
No -
No
you might be right about this being a bug. Have you made a bug report in the repo yet?
Not yet. Where can / shall I create the bug report? Many thanks!
Thx for the link. I created the following bug report: Value mapping not working correctly for 2nd secondary axis · Issue #41920 · grafana/grafana (github.com)
