Value Display Is Wrong In Alert
I show all the correct labels in alerts. However, the Value shows the following:
It’s on the alert page, the email and Teams message this way. However, if I use {{ $values.C }} in the message the correct value shows
The value is in float64 and it is displayed that way. However, when you use template {{ $values.C }} you actually address the Value struct which has overridden String method which prints Value without fractions. If you write it {{ $values.C.Value }} you will get the value in the same scientific format
How do I get it to not display the scientific format?
