I am trying to build a dashboard using 2 sets of data: one set has the server names as FQDN (k8s related) and the other is just the simple server name (node exporter data). I want to show some metrics for the nodes from the node_exporter data.
My Problem:
If I have my “node” variable set to allow “ALL” as an option (so I have metrics from all nodes) then the node_exporter queries also use the “all” which returns metrics for servers outside the cluster.
My variable query:
which works great but then I either need to make sure and reselect all the nodes when I start the dashboard or change the $datasource OR if I use the all I get the issue of all servers being returned for my node_exporter query. There are not any other common variables I can use to filter out the node_exporter metrics. I tried to have a hidden variable for the node_exporter data but was unable to get it to auto select all values that came in from the main variable without it also processing ALL even if the hidden variable does not allow an all value.
Possible solutions:
- Is there a way to process a variable’s actual values without the “all” getting passed on? This could include forcing a variable to always select all values in the drop box without having all
