We just started using Loki instead of fluentbit. I came across using pattern for splitting logs to labels, and that too many labels means too much space. So it makes sense to have labels only when needed. However, I couldn’t find a way to apply pattern in logQL, and then filter on the parsed labels.
Any pointers to the documentation/examples is very welcome!
patterns are used like regex to extract labels from the logs - they don’t create actual labels. “Too much space” - I think you mean “too many streams” - which is what results when you send actual labels to loki in the log data. So using “patterns” to extract “labels” comes at no cost to storage AFAIK - and is faster than regex for the same use. reference here for samples & explanation
