I’m having troubles to configure a repeated canvas panel with a button.
Repeated panel uses multiple-value varaible called “ids” to create several canvas panels in a row. These panels have a button that post data in json format and this data should include the id of the generated panel.
So far, I can use ${ids} in panel title but not in JSON post.
Example 1:
{"id":"${ids}"}
Result 1 is:
Object
Example 2:
{"id":"${ids:json}"}
Object
0:"1"
1:"2"
2:"3"
3:"4"
In both examples, the problem is that the variable in post is getting all selected values but not the specfic for that panel.
I tried using it in the URL but the result is the same.
Any suggestion?
Thank you in advnace,
Carlos
