Using k6 converter :"ReferenceError: cheerio is not defined"
Hello ,
In postman I am using cheerio to parse some html response . After conversion I get “ReferenceError: cheerio is not defined” :
ERRO[0003] ReferenceError: cheerio is not defined
running at post (file:///C:/prj/vbc/k6/k6-rest-api.js:82:27(11))
default at executePostrequest (file:///C:/prj/vbc/k6/libs/shim/core.js:1250:11(23))
        at file:///C:/prj/vbc/k6/libs/shim/core.js:315:30(27)
        at file:///C:/prj/vbc/k6/k6-rest-api.js:57:21(18)
        at go.k6.io/k6/js/common.Bind.func1 (native)
        at file:///C:/prj/vbc/k6/k6-rest-api.js:56:17(13)  executor=per-vu-iterations scenario=default source=stacktrace
Manualy adding the following extra imports sort of makes it work :
  import  cheerio from "./libs/cheerio.js";
  import URI  from "./libs/urijs.js";
The problem is now that it takes 3 minutes with laptop fans maxed out to run the simple 1 VU 1 iteration with a few requests test.
I sense that I am importing cheerio that was already imported somewhere else.
Shouldn’t cheerio already be present in the pm converted tests?
looks like import cheerio from “./libs/cheerio.js”; is the culprit . But I need to to parse html to get antiforgery token… and regex feels bad
Hi @ovidiu.buligan!
Welcome to the community forums :wave:
If you’re looking only for a token value, I believe using the functionality of k6/html is possible.
There is an example of parsing HTML.
Also, there is an example of the scenario where a csrftoken is parsing on our test site.
vars["csrftoken"] = res
.html()
.find("input[name=csrftoken]")
.first()
.attr("value");
Let me know if that helps,
Cheers
Hello , I ended up using regex to extract the csrftoken . with something similar to :
const requestVerificationToken = /<input\s+name=\"__RequestVerificationToken\"\s+type=\"hidden\"\s+value="([\w-]+)/.exec(body)[1]
I think it is faster than parsing html and works since we also control the html page that emmits csrftoken . Probably also consume less memory.
If efficiency is a concern, I would recommend using findBetween as it uses only a combination of indexOf and substring operations.
If you are using any script file and getting "Uncaught ReferenceError: x is not defined " which means ‘x’ is either a variable or a method which you are trying to use before declaring it using var keyword. This means that there is a non-existent variable referenced somewhere. This variable needs to be declared, or you need to make sure it is available in your current script or scope otherwise , it will endup throwing this ‘x’ is not defined error . This usually indicates that your library is not loaded and JavaScript does not recognize the ‘x’.
To solve this error: Load your library at the beginning of all your scripts.
There can be multiple other reasons for this issue:
  • Conflict with Other Libraries
  • Path to your library included is not correct
  • Llibrary file is corrupted
  • Working offline (when you use CDN)
