Using Interval variable for my real time dashboard
Hi Team- I’m in the process of creating a real-time operations data dashboard using AMG (Amazon Managed Grafana). I’m working on implementing a dropdown feature that allows users to choose a time period from options like 1 minute, 10 minutes, 30 minutes, 1 hour, and more.
I’ve set up a variable with the type “intervals,” but I’m encountering challenges in creating the appropriate logic for it because many SQL functions are not available in AMG.
The dataset I’m working with includes fields such as MetricName (text), Intervals (timestamp in the “hh:mm:ss” format), Date (date), and Value.
Query:
SELECT metric, interval, date, value
FROM nikegen2_cloudwatch_data_prod_v1
WHERE
        (STR_TO_DATE(interval, '%Y-%m-%d %H:%i:%s') >= DATE_SUB(NOW(), INTERVAL
            CASE
                WHEN :$SelectPeriod = '1m' THEN 1 MINUTE
                WHEN :$SelectPeriod = '10m' THEN 10 MINUTE
                WHEN :$SelectPeriod = '30m' THEN 30 MINUTE
                WHEN :$SelectPeriod = '1h' THEN 1 HOUR
                WHEN :$SelectPeriod = '6h' THEN 6 HOUR
                WHEN :$SelectPeriod = '12h' THEN 12 HOUR
                WHEN :$SelectPeriod = '1d' THEN 1 DAY
                WHEN :$SelectPeriod = '7d' THEN 7 DAY
                WHEN :$SelectPeriod = '14d' THEN 14 DAY
                WHEN :$SelectPeriod = '30d' THEN 30 DAY
            END)
        OR
        (STR_TO_DATE(interval, '%Y-%m-%d %H:%i:%s') >= DATE_SUB(CURDATE(), INTERVAL 1 DAY) AND :$SelectPeriod = '1d')
ORDER BY interval DESC;
