Hi there,
There is a section in grafana docs(Filesystem | Grafana Loki documentation) describing that “However using shared filesystems is likely going to be a bad experience with Loki just as it is for almost every other application”. Then two questions are coming to my mind:
- Could you please clarify what is the exact “bad experience” as I use manila as filesystem and everything looks fine from my side.
- As I mentioned above that manila is used for my system. Is there any bugs or issues to use manila for Loki? I’m considering to GA with manila so I’m a bit worried about the feasibility.
Thanks ahead.
