9.3.0 -
Use a DS variable as DS in other variable -
What happened?
I defined a Prometheus DS variable, and I could select it in the panels and use it in the Dashboard.
Then I defined an AdHoc variable, but the DS variable was missing in its DS list. -
I expect the DS list of AdHoc (or any) variable to include the DS variable, as it is for the Panels. -
No -
Hi @amiryiron,
Thanks for opening this post.
Can you please provide the step-by-step detail of reproduction so that the community can also try to reproduce it?
Thanks.
