9.3.1 on Windows Server 2022 21H2 -
What happened?
Usgin was_connectionpool_create_total metric but not show data in Grafana 9.3.1, I installed prometheus + Grafana to monitoring IBM WebSphere Application Server with metrics application but not list the metric was_connectionpool_create_total in grafana, the application metrics works fine and show the metric with data.
That Grafana show metric was_connectionpool_create_total to using that.
