Use Wildcard in Constant Variable
Hi, I try to use a wildcard in Constant Variable as Definition:
Type: Constant
Value: *
When using the Variable in panel query:
permission_vacancy_pool:($pvp)
The * will be escaper to \\* and the query gives no result:
"query_string":{"analyze_wildcard":true,"query":"permission_vacancy_pool:(\\*)"
I already tried to turn off escaping with ${pvp:raw}
Do anyone know the answer for this problem?
I found meanwhile an solution here
I am useing now ${pvp:distributed}
Even though that work you should probably use ${pvp:raw} instead since distributed is an existing variable substitution.
Thank you for you reply Mr. Efraimsson,
you are right, I shouldn’t use ${pvp:distributed}. There might be side effects I can not grasp.
After your advice I tried again :raw and now everything is working fine.
I do not know, why it has not worked first time i tried.
