So I will see if I can describe what it is I would like to do. I want to display disk space information for different servers and have a graph per Server.
I thought the thing to do would be have a row that repeats for each server that is in a variable.
Then in the row have a repeating graph for each disk that is on the server using a separate variable. The problem is my disk variable has no visibility of the current server in the row so just returns all disks for all servers.
Hi @dp106 . Unfortunately I don’t believe this is possible at present. Essentially, template variables are not computed dynamically on a row-by-row basis, but have a single set of values globally for the dashboard. If interested, see a broader discussion in Having trouble getting nested variables to work together.
