V9.2.11 running as a pod in kubernetes ubuntu base image -
Login to Grafana -
Login using SSO to Azure Directory -
What happened?
When some users try to login to grafana using sso we get the error
AADSTS90015: Requested query string is too long.
To login successfully
It seems I need to change the token_request_method to POST which I tried but the request is still a GET
This is my SSO configuration.
[auth.azuread]
allow_sign_up = true
allowed_domains = mydomain.com
request_method = "POST"
auth_url = https://login.microsoftonline.com/
client_id =
client_secret =
enabled = true
name = Azure AD
role_attribute_strict = false
scopes = openid email profile
token_url =
