Use labels of one metric for filtering record for other
Hello, I have two metrics:
  1. node_filesystem_files
    node_filesystem_files{device="/dev/nvme0n1p1",endpoint=“metrics”,fstype=“xfs”,instance=“10.64.0.113:9100”,job=“node-exporter”,mountpoint="/",namespace=“observability”,pod=“prometheus-prometheus-node-exporter-kpjhq”,service=“prometheus-prometheus-node-exporter”}
  2. kube_node_role
    kube_node_role{endpoint=“http”,instance=“10.64.43.50:8080”,job=“kube-state-metrics”,namespace=“observability”,node=“ip-10-64-0-113.ap-southeast-1.compute.internal”,pod=“prometheus-kube-state-metrics-69447598b7-fkshq”,role=“solr”,service=“prometheus-kube-state-metrics”}
Problem statement:
I want to filter node_filesystem_files on basis of “role” which is present in kube_node_role. The common link in both the metrics is instance. Can someone suggest a way or query by which both the metrics can be linked to generate output of node_filesystem_files based on roles.
Thanks in advance
