I’m looking to merge some SNMP interface metrics. Most metrics use the same fields, but not all. For example, the interface type metric returns its value in a field.
you can accomplish a lot with Grafana’s transformations, even without using the join. If you’re still blocked on this the community might want to know what your data looks like now and how you want it to look like transformed:
My ultimate goal is to display for all interfaces their metrics in a table. Using the merge transformation gets me most of the way, with the notable exception of ifType with its additional label.
