Use a filter in a Dashboard variable
I search to use a filter as a variable in dashboard variable.
the tag filter is located in the same measurement.
I use fluxquery with an InfluxDB Data source.
I tried this:
import “influxdata/influxdb/schema”
schema.tagValues(
bucket: v.bucket,
tag: “MyTag”,
predicate: (r) => r._measurement == “serial” and r.serial == ${serial},
start: -365d
Is it possible ?
Many thanks for help.
