UQL query for JSON data
I want to transform below data in grafana such that I have 3 columns.
  1. for vhost e.g. www.google.com
  2. for 1st value under sent_bytes i.e. 1741421400 (epoch)
  3. for 2nd value under sent_bytes i.e. 204626090 (bytes)
Can someone please help me write a UQL query to transform the data as needed?
Below is the data:
  "vhost": {
    "www.google.com": {
      "metrics": {
        "sent_bytes": [
            1741421400,
            204626090
            1741421460,
            32288988229
            1741421520,
            30957862076
            1741421580,
            32160304293
            1741421640,
            32199266036
            1741421700,
            31333896590
    "2ndvhost": {
      "metrics": {
        "sent_bytes": [
            1741421400,
            0
            1741421460,
            517576
            1741421520,
            0
            1741421580,
            0
            1741421640,
            0
            1741421700,
            0
    "3rdvhost": {
      "metrics": {
        "sent_bytes": [
            1741421400,
            0
            1741421460,
            456499281
            1741421520,
            444765703
            1741421580,
            477708716
            1741421640,
            439811300
            1741421700,
            409478691
Welcome @tanmaymadan95
What have you tried so far?
Check out this document also
https://try.jsonata.org/oHcVGcQR6
Hello @yosiasz
I was able to achieve the result and create 3 columns writing below UQL query, however now I also want to add a filter on top so I can filter out traffic according to the domain/vhost. I have added a variable and also able to see the list(values of hostnames), but it is not yet integrated with the GRAPH. What should I add in the UQL query to make it happen? can you help?
parse-json
scope “vhost”
project kv()
extend “sent_bytes”=“value.metrics.sent_bytes”
mv-expand “sent_bytes”
extend “vhost_name”=“key”
extend “Time”=unixtime_seconds_todatetime(“sent_bytes[0]”)
extend “bytes”=“sent_bytes[1]”
project “vhost_name”, “Time”, “bytes”
what does the Table view show when you implement that UQL
Hiding hostnames for confidentiality
Can you help me how can I integrate the variable with the data? Currently selecting the variable doesn’t work.
please create a new thread as variable issue was not in the original post
Created a new topic.
Thanks!
