[UQL][CSV] Logical operators in filters
I have tried to use logical operators in filters with the different parsers, but I have not succeeded. is it even possible?
Each of the conditions works separately.
Type: CSV
Method: GET
Parser: Backend
APP =~ "(?i)($SERVICE.*)" AND ENV == "$ENVIRONMENT"
Status: 500. Message: error getting data frame. error applying filter. filter expression for row 0 didn't produce binary result. error: %!w(<nil>). Not applying filter
Parser: UQL
parse-csv
  where "APP" =~ "(?i)($SERVICE.*)" and  "ENV" == "$ENVIRONMENT"
Error Applying UQL query
For uql filters might want to look here, there is no where clause
https://grafana.github.io/grafana-infinity-datasource/docs/filters
You are right @yosiasz , where clause is for json.
I have checked the information in the link you sent but haven’t seen anything about applying logical operations to a filter. I guess it is not possible, even using Backend Parser.
Can you please confirm this?
Thanks for your quick reply
please post sample csv with proper column names
Just three columns
Environment,Service,Application
DEV,http://dev_enpoint_clients,CLIENTS
STAGE,http://stage_enpoint_clients,CLIENTS
PROD,http://prod_enpoint_clients,CLIENTS
DEV,http://dev_enpoint_register,REGISTER
STAGE,http://stage_enpoint_register,REGISTER
PROD,http://prod_enpoint_register,REGISTER
DEV,http://dev_enpoint_intsg,INTSG
STAGE,http://stage_enpoint_intsg,INTSG
PROD,http://prod_enpoint_intsg,INTSG
Changing “AND” to “&&” has worked.
