grafana-9.3.2-1 rpm and redhat enterprise 7.1 (Maipo) -
We are trying to upgrade to latest version 9.3.2 -
As this is offline installation, we have downloaded grafana (9.3.2) rpm along with simpod-json-datasource-0.5.0.zip and alexanderzobnin-zabbix-app-4.2.10.zip and spin up the ec2 instance, - What happened?
With working previous version, we had following configuration in grafana.ini
protocol = https
auth ldap → enabled = true
cert_file location
In datasources.yaml for zabbix
access: Server
basicAuth: true
withCredentials:false
isDefault:true
I tried to upgrade with new version with same configuration, I faces following issues
1.The zabbix plugin was not enabled, wanted some advice as this is offline server how can i bake ami with enabled plugin or when it launched it should be enabled
2. When I tried to click on enable in UI it gives “origin not allowed”,
3. Dashboard gets launched in firefox but it its failed to load in Chrome asking me to check the root_url and subpath . I have verified the grafana.ini for both the version and found some difference , in old version root_url is “http://localhot:3000”. I tried to change the same in new version along with setting cookie_secure = false and cookie_samesite = disabled but no luck
Dashboard should have launched with existing configuration - Can you copy/paste the configuration(s) that you are having problems with?
Mentioned above , happy to provide more info if required - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
“origin not allowed” - Did you follow any online instructions? If so, what is the URL?
Upgrade Grafana | Grafana documentation
