Hello
I am running on a virtual machine (LXC) under proxmox a debian buster with grafana and influxdb.
As i want update influxdb i have to first update debian to bullseye.
So first i update debian with this instruction to debian 11
sudo apt full-upgrade
sudo apt autoremove
sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list
sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list.d/*.list
sudo sed -i 's#/debian-security bullseye/updates# bullseye-security#g' /etc/apt/sources.list
export LC_ALL=C
sudo apt update
sudo apt upgrade
sudo apt autoremove
sudo systemctl reboot
but after this i cant start grafana anymore - i tried to uninstall install it, also to uninstall before updating then installing it… now chance, and looks like this:
root@datenTest:~# sudo systemctl status grafana-server
* grafana-server.service - Grafana instance
Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2023-01-23 21:50:05 CET; 4s ago
Docs: http://docs.grafana.org
Process: 653 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/g>
Main PID: 653 (code=exited, status=226/NAMESPACE)
CPU: 28ms
Jan 23 21:50:05 datenTest systemd[1]: grafana-server.service: Main process exited, code=exited, statu>
Jan 23 21:50:05 datenTest systemd[1]: grafana-server.service: Failed with result 'exit-code'.
Jan 23 21:50:05 datenTest systemd[1]: grafana-server.service: Scheduled restart job, restart counter >
Jan 23 21:50:05 datenTest systemd[1]: Stopped Grafana instance.
Jan 23 21:50:05 datenTest systemd[1]: grafana-server.service: Start request repeated too quickly.
Jan 23 21:50:05 datenTest systemd[1]: Failed to start Grafana instance.
update influxdb works fine too
Thanks for help
