UPDATE $__timeFilter variable
Hi everyone, hope you’re doing well.
-I’m on debian and using v10.0 Grafana
  • I want to update the value of the date Picker selected by the user for one panel to get on my dashboard a panel with the previous informations of a working period.
    For example, if this date is selected :
    I want to search in my database for this date with a -8 hour interval.
-I tried to modify directly the value of the timeFilter variable with SQL but i doesn’t work:
Unmodified timeFilter =>
And i try to achieve this =>
Thanks for helping :slight_smile:
try this
SELECT
  employee_name,
  Time_Stamp,
  activity
FROM working_logs
WHERE Time_Stamp BETWEEN
  TO_TIMESTAMP($__from / 1000) + INTERVAL '8 hour'
  AND
  TO_TIMESTAMP($__to / 1000) + INTERVAL '8 hour'
For past 8 hour
Thank you so much for this MySQL solution.
I have founded another solution with the QueryOptions, setting the parameter ‘Time shift’ :sweat_smile:
Thank you guys
