I am using the MongoDB data source to read data from my mongoDB.
I have installed the “Data Manipulation” plugin to be able to update my documents in the database.
When trying to update my record, I have the following error:
Content-Security-Policy : The page’s settings blocked the loading of a resource (connect-src) at [my private endpoint] because it violates the following directive: “connect-src ‘self’ …”
(content_security_policy_template)
Grafana is by default blocking request to unknown urls. Regarding the official documentation, I should be able to update the Content-Security-Policy to allow the traffic. The problem is that I am using an Azure Managed Grafana so I cannot access the grafana.ini file.
- How can I update my document in MongoDB without touching to the Content Security Policy?
- How can I update the SCP settings with Azure managed Grafana ?
- Can I use the Grafana API to update a document to MongoDB (via the source)?
- Is it possible to update Grafana settings from Javascript?
- Do you have any workaround to propose?
Thank you so much,
