On your pi search for all services running and post back
I were able to remove it with purge grafana-rpi but I got these to warnings:
dpkg: warning: while removing grafana-rpi:armhf, directory '/etc/grafana' not empty so not removed
dpkg: warning: while removing grafana-rpi:armhf, directory '/usr/lib/systemd/system' not empty so not removed
then I tried:
pi@raspberrypi:~ $ sudo apt purge grafana*
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package grafana backup
E: Unable to locate package grafana-rpi_7.4.3_armhf.deb
E: Unable to locate package grafana-rpi_7.4.3_armhf.deb.1
E: Unable to locate package grafana-rpi_7.4.3_armhf.deb.2
then I reinstalled grafana with the tutorial for Rpi
now it seems to be there
pi@raspberrypi:~ $ apt-cache policy grafana
grafana:
Installed: 10.0.3
Candidate: 10.0.3
but unfortunaltey if I connect with grafana with my browser it still shows version 7.4.3…
If I use
ps -A
I see grafana-server in the list
it works now,
thank you! I had to restart the service and then version 10.0.3 appeared!
