Unset annotation editor variables
I’m working on a plugin that I’m upgrading to use Grafana 7.2’s React support for annotations. This adds drop downs for fields such as “time”, “timeEnd”, “title”, etc. However, once you click on one of the options, there is no way to unset it. Here’s a picture of things that are selected. It probably makes sense to not allow people to unset “time”, but the other fields should be able to be unset. Is there a way to change this on my plugin’s end, or is this something that needs to be fixed?
This shouldn’t be the responsibility of the plugin IMO. I think it’s reasonable for the user to want to undo setting a field. Would you mind creating an issue for this?
Yup. Here it is: Unset annotation editor variables · Issue #47452 · grafana/grafana · GitHub
