- What is your Grafana version?
8.3.6
- Are you using Grafana Cloud or self-hosted Grafana?
Grafana OSS on Openshift cluster
- Are you using legacy alerting or Unified Alerting?
Unified Alerting
Trying to restrict/filter alerts by context from datasource yaml configs
Tried to use customQueryParameters in jsonData section
- What happened?
Solution above didn’t work for me still showing all the alerts from all contexts
To find a way of filtering alerts by context in provisioned alertmanager datasource if it is supported
