Understanding of grafana internal metrics
    8.0.4
    Dashboard for internal grafana metrics
    Creating dashboards from grafana metrics scraped by prometheus
  • What happened?
    Metrics shown that I do not understand
    Understand said metrics
My problem is the understanding of the following metrics - what exactly are they telling me?
# HELP grafana_live_node_num_channels Number of channels with one or more subscribers.
# TYPE grafana_live_node_num_channels gauge
grafana_live_node_num_channels 12
# HELP grafana_live_node_num_clients Number of clients connected.
# TYPE grafana_live_node_num_clients gauge
grafana_live_node_num_clients 17
What exactly are these values showing me? And what is the difference between number of clients and number of users?
    Couldnt find any explanation of the metrics!
