Unable to start Grafana using the singularity instance start command
I was able to get the instance up. There were a couple of options missing in the command which I discovered after running our build.sh script.
#!/bin/bash
sudo -E singularity build grafana.sif grafana.singularity
sudo singularity instance start
–pid-file /run/grafana.pid
-B /var/lib/grafana/data:/var/lib/grafana
-B /var/lib/grafana/config:/etc/grafana
grafana.sif
grafana
