I have Node Red, Influxdb and Grafana installed on a W10 computer, all is well on that computer. However I’m unable to get the Grafana dashboard to load on a second computer (W10) on the same network.
Both Node Red and Influxdb dashboards work ok on the 2nd computer
I’m using the format http://192.168.1.111:3000/ but just get an error site can’t be reached - the ip address is definitely correct.
Any suggestions?
Thanks
Paul
