Unable to read .pem cert using open()
k6 v0.45.0 ((devel), go1.20.5, darwin/arm64)
Trying generate k6 script by injecting .pem for both crt and key
    By reading .pem using open() and passing in options
    kept cert in same folder
  • What happened?
    unable to read cert using open()
    Expected load test on my end points
ERRO[0001] TypeError: Value is not an object: undefined
at setup hint=“script exception”
Hi @sub :wave:
Thanks for the information you’ve provided.
It would, unfortunately, be hard to say what the problem you are encountering might be as is. As is would be challenging to find out or reproduce the issue you are experiencing without seeing the code you’ve been using.
Can you paste an example script here that reproduces the issue? It would help us help you :handshake:.
PS: If you do post a script, make sure you anonymize it.
Thank you :bowing_man:
