Unable to join Time Series data with reference data from another table
I have created a Dashboard with 2 panels:
  • One with my time series data in a table
  • One with my reference data
I add a new panel and choose the 2 panels from the Dashboard Data Source and place my time series panel first. I add a transformation to rename the relationship field similar to that used in the reference data panel.
I add a transformation to perform a JOIN (none of the types do anything) and choose the common field. Nothing happens.
I have tried all the types, but nothing happens.
What am I doing wrong?
Table 1:
Cust_ID | @timestamp
Table 2:
Cust_ID | Contract_Type
Join by Field I choose Cust_ID, but nothing gets added…
  • Double/triplecheck that the data types are the same. Cust_ID “1” will not match to Cust_ID 1 (Integer vs. string)
  • Double/triplecheck that there are overlaps in values and that your JOIN type is the right semantics for your case
what is your datasource for each queries? mysql? postgres? ms sql
Thanks for suggestions, but still no luck.
  • Columns are definately String (I even added transforms to both tables for good measure to convert to string, but still nothing)
  • There are definately matching records in both; I also tried all the JOIN types, but nothing appears (not sure is there is an Apply option, or if I need to save first or do something else for the merged columns to appear?)
  • Data is coming from Elasticsearch (using the Elasticsearch connector)
