Trying to display live json data in line graph -
using JSON API i passed value to ling graph -
What happened?
i am able to see only one dot /point and not line graph -
i wated to see the line (time series line graph) graph -
can you view your data using the table panel? Or inspect the panel?
also share your query and grafana version
