v10.4.1 -
I’m attempting to use the default text widget to display the ad-hoc filters as part of a template. This dashboard is intended to be used as a discovery dashboard to use the queries they build to populate a yaml configuration later. -
I have a variable calledadditional_filters
that is set as an ad-hoc filter.
Then in the text widget it’s using HTML and this setup for the configuration…
<div class=\"box\"><pre>
<code>slos:
${DS_PROMETHEUS}-slo:
objective: ${objective}
latencySLI:
metric: ${main_metric}
commonFilters:
- ${additional_filters}
errorFilters:
- le="${latency}"
</code></pre></div>
<p>
Some additional template instructions....
</p>
What happened?
The${additional_filters}
reference for “commonFilters” always shows up blank. Tried a couple different variable syntax options which doesn’t display the variable either. There weren’t any errors in the Grafana UI. -
The ad-hoc filters to be displayed in the text widget. -
Additional Comments
I expect it’s the way ad-hoc filters are handled and only are added to queries that is why it’s not being displayed. I’m sure there is a way to achieve this via a custom panel but just want to check that I’m not missing something using the default Grafana panels/templating.
