I am trying to implement a custom HTTP call for variable substitution with type Query in datasource-backend-sdk-go plugin.
Followed the steps mentioned in this article and was able to capture the query input from the Variables page.
I have overridden metricFindQuery method in datasource.ts file and made call to backend using postResource() method.
Here’s how my metricFindQuery
and CallResource
method looks
async metricFindQuery(query: string, options?: any) {
const response = await this.postResource('facet-query', { query: query, test: 'val' });
func (d *DataSetDatasource) CallResource(ctx context.Context, req *backend.CallResourceRequest, sender backend.CallResourceResponseSender) error {
var fm filterModal
err1 := json.Unmarshal(req.Body, &fm)
type filterModal struct {
query string `json:"query"`
So, the issue is, the documentation says req.Body should have the data that has been passed through postResource
method. But when I try to access the data, it shows an encoded string in bytes format, and Unmarshall always returns empty.
Any help on this is appreciated
