UI improvement suggestion
Hi, I would suggest you to add a cog icon to expose the panel controls menu. It can be placed next to the panel title, may have an appropriate tooltip, and will make the menu location more obvious for users.
The same can be done for rows.
Thanks for the feedback @yakov! There are some big enhancements coming in v5 that will address this very concern.
Keep an eye out.
Is there a timeline on V5?
