Typescript decorator using not possible
I’m developing a panel plugin in typescript. I want to use a typescript decorator.
I get the following error:
Module build failed (from ../node_modules/swc-loader/src/index.js):
Error:
  × Unexpected token `@`. Expected identifier, string literal, numeric literal or [ for the computed key
Even adding "experimentalDecorators": true to the tsconfig.json and/or installing the npm install @babel/plugin-proposal-decorators does not solve the situation.
Does anybody know how to solve it?
@phdehner the default configuration that comes with create-plugin might not support decorators. You’ll have to extend the configuration and add support yourself. here’s how to extend the configuration for a plugin Extend configurations | Grafana Plugin Tools
The specifics of how to add support for decorators is up to your configuration extension.
Mhm okay… Thanks
