Hi
In my custom plugin I’m trying to import the FieldValidationMessage for displaying validation errors on inputs.
this method doesn’t work for me:
import { FieldValidationMessage } from “@grafana/ui”
this one does work:
import { FieldValidationMessage } from ‘…/…/…/…/…/…/…/…/…/packages/grafana-ui/src/components/Forms/FieldValidationMessage’
I don’t like calling a file outside of my plugin.
How can I import FieldValidationMessage from “@grafana/ui” ?
Hi, looks like FieldValidationMessage
isn’t exported from @grafana/ui
yet, so using import { FieldValidationMessage } from “@grafana/ui”
isn’t possible.
I’m wondering what use case do you have for it, since FieldValidationMessage
is mean to be used with the Field
component to show form errors?
@alexkhomenko
Thanks for your replay,
yes I’m using it as a form input validation field.
So is using the Field
component with error props doesn’t cover your use case?
I’m not using the Field
component.
Does it include the validation label ?
It has an error
prop for the error message and invalid
prop to indicate if the error should be shown: https://developers.grafana.com/ui/latest/index.html?path=/docs/forms-field--simple
Thanks @alexkhomenko
I was using the input field.
Will try out, instead.
@alexkhomenko - I’m getting the error, Field is not an export member of grafana-ui.
my package.json is using:
“@grafana/ui”: “next”
what is wrong here ?
Which grafana version are you running this in? Try deleting node_modules
and yarn.lock
in your plugin and running yarn install
