Trying to append a word "jira" via the Rename by Regex transformations
Hello @krishvoor,
Welcome to the forum!
The variable you put in the replace field looks weird… Can you take a screenshot of the query, I don’t need the query but the name:
Regards
hi, have you tried the concat function? I’m using BMC Postreg SQL so not sure how your syntax goes, but it may be something like this.
SELECT
  CONCAT ( t."mem_total", ": JIRA") AS mem_total
FROM
cheers,
