I am forwarding a value from one table to another template varriable of dashboard
that works perfectly fine…but actually i want to trim the value which i am sending
So, in $__cell can i trim it?
Lets suppose the value is Grafana.Pull.Request
i need to forward only Grafana.
Yes, this feature can be useful for my usecase too…+1
That’s not supported. Please see issue which solved the render table cell as link. Probably better that you create a new feature request issue for this and add a reference to #3754 in description. If a lot of people upvotes this with a
in the issue we’ll consider implementing this.
Marcus
