I’m trying to setup some alerts on conversion rate which is evaluated every hour. For example, if the conversion rate after 1 hour fall below 70%, it should through an alert. If the conversion rate is still below 70% after 2nd hour, it should through an alert again which I’m not getting because the state remains same. Could you suggest a way to resolve this?
