I have enabled Metrics Generator with local blocks
only for out distributed tempo deployment to test it’s potential .
The problem I are facing now is that only the last 30m window of time is TraceQL metrics available to test . I have deployed Metrics Generator as a Stateful Set with persistence enabled.
I don’t want necessary to increase the window , I only want to run the query with an interval of 10m starting from 5h ago.
The rendered Metrics Generator config inside the k8s cluster is :
metrics_generator:
metrics_ingestion_time_range_slack: 30s
processor:
local_blocks:
filter_server_spans: false
service_graphs:
dimensions: ]
histogram_buckets:
- 0.1
- 0.2
- 0.4
- 0.8
- 1.6
- 3.2
- 6.4
- 12.8
max_items: 10000
wait: 10s
workers: 10
span_metrics:
dimensions: ]
histogram_buckets:
- 0.002
- 0.004
- 0.008
- 0.016
- 0.032
- 0.064
- 0.128
- 0.256
- 0.512
- 1.02
- 2.05
- 4.1
registry:
collection_interval: 15s
external_labels: {}
stale_duration: 15m
ring:
kvstore:
store: memberlist
storage:
path: /var/tempo/wal
remote_write:
- metadata_config:
send_interval: 1m
send_exemplars: true
tls_config:
insecure_skip_verify: true
url: http://prom-stack-kube-prometheus-prometheus.monitoring.svc.cluster.local:9090/api/v1/write
remote_write_add_org_id_header: true
remote_write_flush_deadline: 1m
wal: null
traces_storage:
path: /var/tempo/traces
multitenancy_enabled: false
overrides:
defaults:
metrics_generator:
processors:
- local-blocks
per_tenant_override_config: /runtime-config/overrides.yaml
Sample output for 1h
Is there a way to increase the ‘retention’ of local blocks ?
