Tool for debugging your plugin with accelerometer
Hey
Our team develops plugins for Grafana and we noticed that you often need some time series data to test your plugins.
I propose to use Accelerometer2Influx app which sends data from your phone accelerometer directly to InfluxDB. Now you can simulate signals by shaking hand.
Thanks for sharing.
The Grafana TestData data source is very convenient for this use case.
Also, we have a lot of test data for different data sources using docker-compose in grafana repo together with https://github.com/grafana/fake-data-gen.
Marcus
Hey @mefraimsson
Is there anything else except csv and random walk?
  • With accelerometer you can generate signal a bit more precise than pure random (and it regenerates of each request, so you can`t see graph “moving” to the left)
  • With csv it’s a bit hard to maintain big datasets and no ability to generate real time data
I guess it depends on what you actually want to test. With the randow walk you always get data even if you’re zooming out/in.
Marcus
