I have previously installed grafana on windows using docker but this time I wanted to try and use it on a Linux server on Azure. I created a fresh Ubuntu 16.04 VM and followed the steps in this tutorial https://www.howtoforge.com/tutorial/how-to-install-grafana-on-linux-servers/#comments
I followed all the steps to the point except
echo ‘deb https://packagecloud.io/grafana/stable/debian/ jessie main’ > /etc/apt/sources.list.d/grafana.list
which I am guessing is not important as I was able to download and install the packages anyway.
The problem arises when I try to execute
sudo systemctl enable grafana-server
It gives me the output:
Failed to execute operation: Too many levels of symbolic links
What could be the reason for this? This is a fresh VM with these being the only commands I have executed on this VM.
