The SQL generated on a dashboard panel:
SELECT
timestamp AS "time",
id AS id,
cast(value as double) AS "value",
key
FROM 'gvo-logging'
WHERE key = 'System/Memory Usage' AND timestamp BETWEEN '2022-05-24T13:10:39.428Z' AND '2022-05-24T14:10:39.428Z'
executes fine on QuestDB over PSQL
When using the same SQL in an alert rule, the granularity of the timeFilter is much greater, and causes the query to fail:
SELECT
id AS id,
key
FROM 'gvo-logging'
WHERE key = 'System/Memory Usage' AND timestamp BETWEEN '2022-05-24T14:05:58.160103525Z' AND '2022-05-24T14:10:58.160103525Z'
SQL used in alert query:
SELECT
id AS id,
key
FROM 'gvo-logging'
WHERE key = 'System/Memory Usage' AND $__timeFilter(timestamp)
Grafana v8.5.1 (61fe4a1859)
