Time Series + Stat on the same chart/panel?
Is there a way to overlay a number onto a time series chart?
Say you wanted the current value to be displayed as a number?
The stat chart type adds a trend line but you lose usability, not exactly what I’m looking for.
If the answer is no, next best is to make another panel as stat and place it near the time series panel. Would be cool to have on one though.
you should start a discussion in the repo for the feature! :+1:
The metric is hashrate and it’s a huge number. Grafana seems to be having trouble displaying a Y axis value for this specific metric.
Other metrics seem to work fine.
How can I get around this? I set the unit to hash, short, etc. Nothing seems to work.
