Time series data display issues
    Time series data displayed
    Loading the data in a dashboard
  • What happened?
    The date is interpolated weirdly
    Less weird data interpolation
    Below
    No
    No
I have some weird data visualisation issues I was wondering if anyone could help me with.
If I filter my SQL statement with WHERE ${__timefilter()} variable, there are weird anomalies in the data. If youzoom in to the time series the data is fine, but when viewing 2+ days there are graphical glitches. The dash is actually interpolating (skipping) data points (even though there aren’t too many datapoints to display) and I think that is causing the issue. If I remove the timefilter, it downloads all the data in the database (over a year), and then displays 2 days of data perfectly.
Does anyone have any ideas on what I can check? It works fine without the Timefilter but it is a bit slower and wasteful…
