Time range does not reflect graph range
Hi, I have noticed this 2 years ago already, and still observe the same problem after reporting it as a problem:
Selecting a time range does not result in that time range showing the graph.
Whatever range I select, and whatever labels, I only seem to be getting 15 minutes to a couple of hours of data shown in the graph. Selecting 7 days with {app!="somethingnotexisting"} should come up with everything not matching that label I presume. Unfortunately the results are always unpredictable and as such all members of my team have abandoned using loki. Sad :frowning:
Here is the config used:
auth_enabled: true
chunk_store_config:
  max_look_back_period: 24h
ingester:
  chunk_block_size: 262144
  chunk_idle_period: 15m
  chunk_retain_period: 1m
  lifecycler:
    ring:
      kvstore:
        store: inmemory
      replication_factor: 1
  max_transfer_retries: 0
limits_config:
  enforce_metric_name: false
  reject_old_samples: true
  reject_old_samples_max_age: 24h
schema_config:
  configs:
    index:
      period: 24h
      prefix: index_
    object_store: filesystem
    schema: v9
    store: boltdb
server:
  http_listen_port: 3100
storage_config:
  boltdb:
    directory: /data/loki/index
  filesystem:
    directory: /data/loki/chunks
table_manager:
  retention_deletes_enabled: true
  retention_period: 24h
