Threshold range in Status Panel
hope you can help me, i can’t find the solution for my problem.
I’m using the Status Panel in the newest Version.
There is described, i can use a range for warning and critical. How must i put in the range.
I want to switch to critical when the metric is not 0.
Like 1 to 100 for critical.
Thanks,
Helge
Would setting both Warning and Critical to 1 work? If the value is 1 or greater then it would be Critical.
Thank you, it helps to think easy. :smirk:
